ricebike »
https://forums.nicoclub.com/ricebike-u5064.html
Tue Apr 15, 2003 4:27 am
hi i also have python injectors installed about 2 years ago... but i'm not having problems w/ it.
i'm not a mech, but i'm guessing your ecu is reading someting that maybe your engine is too cold: check for codes to see if maybe you have a malfunctioning temp sensor, that 2-plug connector near the air bleed valve, not that 1 wire connector for your dash gauge.
that's 1 of many problems... since your flooding your car, i'm guessing the filter isn't cloggin up so that can be in the backburner til you find the main cause.
there's also a test to see if your fuel pressure regulator is up to par.
another thing, maybe you got crappy new injectors... might have to switch them out w/ replacements... theres a test for that as well... removing the fuel rail w/ the injectors still connected, turn key on but not to start the car, hear that fuel pump pressurize the fuel system, then check to see if your new pythons are leaking....
good luck!
