**New** PWR Blow Off Valve Exclusively From RPSport
Look here for specials on Nissan parts, accessories or modifications, or tell our sponsors what you are looking for!
johngriff
Car: 240sx
Blue on Black, CNC Aluminum. This Blow off valve is the real Deal.
PWR Blow Off Valve
After 2 years of testing, I am happy to announce the US launch of this Blow off valve. We have personally put this valve to the test. It brings together the stregnth of the Tial, while maintaining adjustability. Unlike the HKS and others, there are no plastic parts that wear over time. Greater than Sheep Dog, ARC, and Prof, air exits from all sides to not cause restriction that can be compressor wheel critical in high CFM turbo systems.
Visit http://www.RPsport.net to order yours, order to delivery takes 7-10days.
Here is more info off of our Site!
""Consisting of Only 4 Main pieces, it is the most durable and reliable blow off valve on the market today. Compared to other Japanese Manufactured Blow Off valves, the PWR out performs by leaps and bounds. Competitor blow off valves, use Plastic internal and wear pieces, which can bring product life down to just a few short years.
Most designs also force exit air flow through a strict 90 Degree Bend. This limit in airflow can cause compressor surge in larger Compressor/Housing applications. With the Increased price of turbo chargers today, especially the GT series, it only makes sense to use the best blow off valve available.
The PWR Blow Off Valve attaches using 4 Allen set screws. There is not tricky or tough install such as the snap ring on the SSQV. The PWR Blow Off Valve Ships with two different attachments. The first a hose fitting attachment, for easy replacement of a stock bypass valve, or a weld-able aluminum flange, for race and custom applications.""
Features
Completely CNC'd Out of Aluminum
Heave duty Spring
Adjustable threaded body adjusts spring tension
No Plastic parts
44PSI maximum (ask about Upgraded Springs for higher boost)
Made In Australia out of the highest quality metals.
Modified by johngriff at 2:07 AM 9/27/2007
180sxfaktory
Car: 1989 RS13 180SX 1991 RMS13 240SX 1992 RS13 200SX
+1 for my bro, John Griffin and RPSport! John is a bonafide guy, tuner and straight shooter! Give him your business!
Return to “Advertisers' Marketplace!”
