First time user, I just purchased a hardbody truck, 1995, 4wd extended cab V6 Automatic for my son who will be turning 16 later this year. This truck was a one owner, and only has 70K miles. It has a few problems though and I need some help to determine if these are specific to this model year or problematic with this truck series.
First, The steering column plastic pieces were removed from the steering column and when I asked the owner about it he said that "sometimes the key will just quit working and he has to give the ignition module a "jiggle" to get it working"... he further noted that he had taken it to a dealer for repair but could not get the problem to repeat. He did tell me that he thought it had something to do with the turn signals?
Second, the headliner has basically eroded away to the point that you now can see the fiberboard instead of the material, is there a replacement head liner?
Third, there appears to be a rubbing sound coming from one of the rear wheels or in the drive line? I cannot determine where it is coming from but I was just wondering if this model was prone to something like that.
Fourth, the cruise control works "sometimes" according to the previous owner.
Sixth, my son is 6'-5" and can fit behind the wheel but he is basically folded into an accordian when this happens. The previous owner said I could re-set the seat rails to permit the seat to slide back further toward the rear of the cab. Is this really possible? If so, how is it done.
Finally, where I might locate aftermarket parts for this model year?
Thanks in advance.
Hayride95
