New Project - CA18DET Roadster
alfred183
With my 240sx long gone, and the desire of having a fast car still alive, I have decided I will be putting a CA into this...
This should be pretty fast. Stock Roadster weighs about 1950lbs...and the CA will be a good 80lbs lighter.
So far, it hasn't been too bad, the car was $350 and the new CA I got was $500, but now I've hit a snag as I have to get a different exhaust manifold to clear the steering shaft as it goes right through where the stock turbo would go...
to demonstrate, here is a pic of an SR20DET in a Roadsterhttp://community.webshots.com/...mhbJZNotice how he had to get a manifold made to clear the steering shaft...
So I have a few questions for you experts....Will the stock manifold mount backwards? Meaning facing up instead of down? Because if that is the case, it might be easy to bypass having to buy top mount manifold and a T3 turbo...I would just have to fabricate a dump pipe (not that hard, I think I can fabricate simple things...
or should I buy one of these?http://cgi.ebay.com/ebaymotors...&rd=1
CA19DET
i would either go with the SS Autochrome top mount (if it can fit) or a custom log syle manifold...
nice project,
i want to stick one of my CA18DET's in my fathers MG B convertible (looks very similar to the datsun roadster) but that will only happen either when he is dead (yikes) or moves to germany to live w/ his 6'2' german wife... lol
good luck
alfred183
Do you know anyone who makes log manifolds for CA?
81na ZX
Car: 81 280ZX, 69 Lotus Europa
You suck. I want one of thoes.
They preatty much don't exist in Michigan, let alone for $350
boost_boy
alfred183 wrote:Do you know anyone who makes log manifolds for CA?
I have one, but it has a T3 flange and was also fitted with a gooseneck pipe for the external wastegate.
Dee
f s t caz
Car: VG30ET D21 Extended Cab Pickup
<3 roadsters
good luck with that. I hope things work out well, I've always wanted a roadster with a properly equiped motor
boost_boy
alfred183 wrote:With my 240sx long gone, and the desire of having a fast car still alive, I have decided I will be putting a CA into this...
I wired up one of these, but convertible and using a KA24DE and harness out of an S14 240sx. Gas tank had to be modified, had to have a custom driveshaft made and a few other mods. But I don't think this guy ever did anything as far as putting it on the road. Well, at least it ran, so I guess I did what I got paid to do "Make it run" . I definitely wish you the best of luck with this one.
Dee
NeedCAforS13
Car: CA swapped S13 coupe
LOL! Don't let Rex (aka Speeddoctor) see this... he has a beautiful roadster and he's mentioned afew times wanting to put a CA in it!
Sean
fallen180sx
Car: 90 Sil80
sweetness..
Not_a_sr
Car: 90 ca18 pwrd 240sx FB
i have all the flanges to make a CA manifold.
Ca manifold flangest3,t4,or t25 Flangeswastegate flangeseven some weldL's think im out a mild, but i gota box of 304SS waiting to be used on a tubular experiment.
alfred183
Hey, Not_a_SR, how much can you hook it up for??
alfred183
Yeah, I need to modify the gas tank and take it to get boiled to get the rust out. I got some goood cutting tools to help me in this project. Should be fun except for the brakes....I'll figure something out....
NeedCAforS13
alfred183 wrote: Not_a_SR
I belive that's Slw240sx (Jon) from back in the day alfy... if you didn't already know that
Sean
BoroBoroS13
Car: S13, RS13, and S14
I LOVE those roadsters!
You could do a RHD conversion to fix that whole manifold problem but its gonna be hard to find everything needed.
Not_a_sr
you want a complete flange set minus the weld L's ? like 50$ shipped. thats manifold flange,t3 inlet flange, wastegate flange.
i have almost every flange you could want... over 60 different flanges.
float_6969
^^^flange whore...
Not_a_sr
yes yes i am.. im a DIY parts whore now does anyone have a junked t28 turbo they arnt needing any more, then ill have some oil line kits for well under a 150$
NeedCAforS13
will a t25 work Jon? We pulled one off my friend's motor to put an SR t25 on there, and its just sitting in my garage... I'll ask if he wants to give it up
Sean
Not_a_sr
actually i just need to take off my t25/t28 oil drain flange i have on the turbo i have on my car, then i can make the drain flanges... shouldnt be to long till i take it off the car and move up to my t3/t4, im just running the t2small for breakin then its on to bigger and better.
float_6969
Not_a_sr wrote:yes yes i am.. im a DIY parts whore now does anyone have a junked t28 turbo they arnt needing any more, then ill have some oil line kits for well under a 150$
im intrested...
Not_a_sr
i thought you are goin t3/t4? if so i already have that kit out. it just doesnt come with coolant lines. since alot of them dont use them.
float_6969
I've currently got the SSAutocrap T28 equal length. I don't know if I can get the power that I want out of it with this setup though. I'll know soon enough though...
