new problem with my klunker...AT gremlin
allensteiner
Car: 1995 Nissan Maxima GLE, 2005 Pontiac Bonneville SE
so i used to have a problem with the transmission shifting a little jerky between 1 and 2 gear...that went away today when my shifter started getting stuck when i put it in park. i have to crank the steering wheel all the way to one side and "knock" it for the button on the shifter to go in...but at least now, when it shifts, it's nice and smooth. anyone know what the problem might be?
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
The steering wheel/shifter issue is odd...
Does the key come out okay when the shifter is "stuck?"Does the wheel turn to full lock even without the key in the tumbler and turned past the release position?
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
Until I had them fixed, I could pull the keys out of my1995and 1998 while they were running-and they would continueto run.
I got the switch fixed on my 95 for about $125
NutriaforBreakfast
If you are parking on a hill, put the car in neutral, put on thee brake, then put it in park. Does that help?
allensteiner
it's always a flat surface when i park. i was thinking that it might be a problem with a brake pedal switch that unlocks the button on the shifter...but why would it unlock when i turn the wheels? the ignition switch is fine. i guess i'll leave it in N, put the e brake on and leave the key in the ignition...glad i've got keyless.
