JoeKansas »
https://forums.nicoclub.com/joekansas-u24701.html
Sat Jan 22, 2005 4:29 am
I pulled the plug on the coil itself and put the voltmeter probes in the socket feeding the coil. From wire to wire, with the key on, I had right in the 12 volt range- with the voltmeter on the 25 volt range. I didn't check voltage from either wire to ground, though. I figured one was the power in, and the other would be a ground? With the probes in, cranking the engine, the voltage would drop from 12 volts, to around 8 to 10 volts. But, I think that is normal because of the cranking current draw. What I did notice was that there was no pulsing of the voltage as the engine turned over. It just went down to 8 to 10 volts as the engine cranked. I thought there should be a pulse of voltage for each time a cylinder should fire, right? Something else I checked was what looks like a ballast resistor. It is mounted right about up to the top of the firewall halfway in from the fender. It has two wires coming out of it going to a wire loom. The thing is white porcelain itself, and has a metal shield covering it. It has continuity, and when I pulled it's connector from the wire feeding it, the input wire has 12 volts. So, whatever it is, it is good. I would like to check the plug connected to the distributor. It has a 4 pin socket, and if I knew what I should have coming out of each wire, I could do that.
