New Pics of the Interior
domdada
Car: 08 A/C 3.5 CVT
I'm not a huge fan of dash kits to dress up the interior of the car, I'm more of a, paint the interior to 2 tone to give it some life. So as I had posted before, I went and got some color match paint to match the Steering Wheel and Door Trims. I also painted the dash kit for my Kenwood DNX 8120 Navi Unit, But I haven't installed it yet so no pics of it yet.
Here's Pics of what I did. I wanna appoligize before hand about the first pic of the dash bezel, The sun was interfering with the pic shot so it doesn't look that clear and has a halo like image.
Gear Shifter Pod
Passenger Side Vents
Drivers Side AC/Heat Vent
Driver Side Defogger/Defroster Vent
I have a couple cans of paint left, If anyone wants to buy them from me to do the same mods, let me know.
-Dom
Colton92
Car: 2008 Nissan Altima Coupe 2.5S - WinterFrost
looks good but can we get some more shots that aren't quite as zoomed in?
Just to be able to take in how good it look?
LegendRacer
any pictures showing the entire job? and how come the paint doesnt seem to be holding on to the edges of the vents?
BlackNWhite
Car: 08 Altima Coupe
Colton92 wrote:looks good but can we get some more shots that aren't quite as zoomed in?
LegendRacer wrote:any pictures showing the entire job? and how come the paint doesnt seem to be holding on to the edges of the vents?
I don't understand what you're describing.
After you show us some of those pics... I'll probably take some of those paint cans off your hands.
domdada
Car: 08 A/C 3.5 CVT
BlackNWhite--I color matched the trims of the heat/ac vents on the dash and the round vents for the defroster/defogger on the dash, the gear shifter pod, and the black trim where the speedometer to the colored trim on the steering wheel(where the radio and cruise control buttons are)
LegendRacer and Colton92--I will take better pics tomorrow and the job as one. I didn't have much time to take better pics of them, I was at work, stepped out for a minute and took them.
Colton92
did you take them off of the dash, steering wheel, etc. when you painted them? Does the paint color match your body paint?
domdada
Car: 08 A/C 3.5 CVT
The steering wheel has that color trim already, so does the door(the part you grab to close the door when sitting in the car).It's the titanium looking color peices. I had the paint color matched to those trim peices, took them off the dash, sanded them down, primered them and them painted them.
BlackNWhite
^Good question. Also, how do you apply the paint? With a brush? You also primer it? I've very interested in doing this mod.
domdada
Car: 08 A/C 3.5 CVT
I pulled vents off the dash, and disassembeled them (which is not hard at all to do), used a 60 grit scuff pad to sand them down, used primer filler(spray can) to prep it, went over the primer with a little bit of oil remover in-case there was any oil smudges from my fingers on there, then the paint I had made were in aresole cans, i sprayed them, let them dry, and put them back together.
*NOTE*
When the primer dries up and it looks rough, use a 100 grit scuff pad and sand down the primer untill it's all nice and smooth. Reapply primer on there, let it dry then, spray it with the final paint.
As to the paint, I posted a thread about the interior paint and wanted to see if anyone wanted a can of it. It's in an aresol can. One can was more than enough for all the peices that I painted, plus there is a lil bit left in it.
NightSky
My g/f's Honda Civic has this except they're separate pieces that glue on (excluding the odometer portion). She had them installed from the dealer. Maybe it's because I'm so tired of seeing them but this mod doesn't seem all that great to me. It's just, meh.
domdada
Car: 08 A/C 3.5 CVT
NightSky--I'm not trying to go all out with this car. My 03 Alti was a different story. That car was built for show, I did everything from air suspension to shaving the door handles with poppers, to a full body kit, custom paint job on the exterior to matching the interior to the exterior paint, to ripping out my back seat and building a custom box with 2 15" Juggernaut Subs and More.
With my A/C, I just wanted to add a little bit more color to the interior. I'm not trying to make this car a show car like my last one, those days are in the past for me right now. I'm not in my teenage/early 20's anymore. I'm thinking about my future, which costs money, so I won't be dumping too much in this car.
I don't know why Nissan stopped with the colored trim on the door and steering wheel? I didn't do this mod to wow everyone and be like "Holy S**t, That's Bad A**". No, I did this because I like to see a little more of the 2 tone in the car.
I'm not trying to sound like a jerk or anything and I hope you don't take offence to this.
NightSky
None taken. I think it is just because I am tired of seeing it that makes me not like it. I'm all for enhancements and not over-the-top mods (even though I like those too). I'm actually planning to go the enhancement route myself like you. I really like your dash mod though. Very simple, yet, it improves the look a lot.
shain_tsung
Car: 08 altima coupe 2.5 s
i just got my fiberglass eyelids today and allready primered and painted them this will probabely be my next thing to do
1) Drop the Steering Column-Put your hands between the bottom of the neck of the steering wheel and the steering column and pull down. This should drop easily, it's a matter of a couple clips being undone.
-Next is the difficult part to describe. The black trim around the dash cluster, where the push start button is, needs to come off. Using 2 hands, put your fingers in between the bottom of the black trim and the plastic glass where the gauges are (where the 2 come together at the bottom). Now with a little force, pull out towards you and it should come loose....again a matter of a couple clips.
do you have a picture of where these clips are? i dont see them but than again my hands can barely fit in there
Modified by shain_tsung at 8:36 PM 7/22/2008
domdada
Car: 08 A/C 3.5 CVT
The clips are on the back side of that trim, you will not see it or feel them with your fingers. Your fingers do not have to go all the way in between, as long as your finger tips are in between and you can get a good grip, Just pull towards you.....both the left and right side at the same time.
BlackNWhite
Hey domdada, do you have a pic that shows the whole interior of the car? If I can just see that, I'll take one of your cans off your hands.
domdada
Car: 08 A/C 3.5 CVT
Sorry I haven't gotten to that yet. I don't have my camera with me right now....so I'm gonna go out to the car and see if I can get a good shot using my phone cam....Give me about 10 mins and I'll be back.
domdada
Car: 08 A/C 3.5 CVT
Here's a Couple of pics, They aren't the best shots....for 1 the sun was out....for 2 it was with my phone cam. I hope this gives you a better idea of what it looks like
domdada
Car: 08 A/C 3.5 CVT
the passenger side pic sucks a**.....lol. I wish I could give you a better shot of it.
ThatGuyRoger
Car: 08 Super Black Altima Coupe 2.5S
FIJI water FTW!
but the 2 tone does really look good. nice work there
domdada
Car: 08 A/C 3.5 CVT
FIJI, EVIAN, AND VOSS.....best bottled water! Oh, and thanks for the thumbs up on the interior, much appreciated
ThatGuyRoger
domdada wrote:FIJI, EVIAN, AND VOSS.....best bottled water! Oh, and thanks for the thumbs up on the interior, much appreciated
lol yessir!
BlackNWhite
I can't really tell from the pictures... but is the color match really good?
Anyways... you take paypal?
domdada
Car: 08 A/C 3.5 CVT
The color matches wonderfully, like i said.....I took the trim panal off the door and took it to an automotive paint supplier, they have a machine that scans the paint and does a color match. I do take pay pal....send it to [email protected].
BlackNWhite
20 bucks right?
BlackNWhite
Payment sent.
domdada
Car: 08 A/C 3.5 CVT
Yeah....$20 will do. I will have that shipped out for you hopefully later today, if not by monday that latest. Thanks again.
Colton92
hey blacknwhite make sure you post sum pics of ur completed install,
