akliquid wrote:Did you have any problems applying vinyl tint over the raised letters on side markers? Did you happen to try to put on your side view mirrors. I'm planning on doing the same on side mirror blinkers and side markers. Do you have any pointers or suggestions? Thanks.
There was no problem installing over the raised letters. You can tell it there but only if your close enough to steal the car. A suggestion you could do is sand down the raised letters, i though about it after i was done. Also when tinting the sidemarkers make sure you dont use to much or to little tint to cover the lens. To little will show the orignal color of the lens around the edge and too much will be a problem to trim. On my second lens i finally got it right....Good Luck.
The ride with the srpings is awesome . Cant ask for much more, when first installed it sat so high. In about 30 minutes I couldnt eve stick my fingers into the wheel gaps settled real fast...almost scary
