Heres some pics of my car and the ca18det I picked up from pacmanvr4 last week. Its pretty clean, has about 86,000 miles on it according to the cluster in the clip it came out of. Ive seen engines with fewer miles that looked alot worse on the inside, lol. It turns over smooth and compression is supposedly about 165 all the way across, and that was on a cold test they did while it was still in the clip it came in, I havn't verified those numbers yet though. I'm in the middle of putting it back together with new gaskets, timing belt, water pump, pcv valve, drive belts, etc. Basically a full tune up. I'm not really wanting to do the rings, bearings, oil pump, headgasket, etc. right now unless its totally needed so hopefully thats all good. Let me know what you guys think. Heres the links:
http://www.imagestation.com/album/?id=4287234029
http://www.imagestation.com/album/?id=4287474423
