New personal best with the little stock motor that could....
Booztd 3
Car: 1990 Nissan 300ZX TT
Had a great time this weekend. Was nice to get to the track and have some beautiful weather. Last weekend I drove all the way up in hopes of racing but got rained out - sucked.
First pass of the day, 14psi in the tires, 5700 RPM 2-step
10.40 @ 140
[youtube]http://www.youtube.com/watch?v=MNyTWq5Y-LU[/youtube]
Second pass, 14psi in the tires, 5500 RPM 2-step
10.28 @ 141
[youtube]http://www.youtube.com/watch?v=jf_W9B_GK1U[/youtube]
[youtube]http://www.youtube.com/watch?v=C5iQXN8VDQw[/youtube]
Third pass, 14psi in the tires, 5100 RPM 2-step
[youtube]http://www.youtube.com/watch?v=H6Vo0Xfkq4M[/youtube]
[youtube]http://www.youtube.com/watch?v=8IAuneK05Rk[/youtube]
Last pass, 14psi in the tires, 4700 RPM 2-step + and a passenger :whacko:
10.3 @ 139
[youtube]http://www.youtube.com/watch?v=S7J8bvbE7RY[/youtube]
I still *REALLY* want to build a motor for this thing over the winter but I'm really hesitant to go tearing this thing apart when its working so well
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Nice passes buddy! Personally, I'd keep running that motor until you can get something else built. It is fast and very consistent and sounds like it has been reliable for you. Are you thinking RB30?
Booztd 3
I would love to go with an 10:1/RB30 however.....I have clearance issues to begin with. I can't drop the motor any further down and I have already spaced the subframe away from the chassis enough that I am comfortable with. The real issue is the compressor housing hitting the hood. I could try and find a way to modify the exhaust manifold to drop everything back down but from what I understand the RB30 is almost an inch taller.
Darius
Sounds like you'll need to clearance the hood (i.e. sawz-all) and graft a turbo intake into it :gapteeth:
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Nice!
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
Great runs! For the future RB30 setup... Dry sump and drop the engine lower :spitout: should save some room and add performance at the same time.
RRRRB
Car: 98 RB powered S14
Awesome its on the stock motor still!
What size tires you running?
Put some Richmond 4.11 gears in that thing and go 9's
I know where a set is at
Booztd 3
RRRRB wrote:Awesome its on the stock motor still!
I have had the richmond's in the car for about 7-8 years now (I had one of the first sets.) With the stock gearing I'd barely be getting into 4th. These are 26x10.5 and the gearing/tire size combo is perfect for where I'm crossing the traps.
The issue I have right now is the output shafts. If I keep the ET streets at 14psi, I can run them all day long. As a matter of fact I have gone 2 years now without a failure. However, If I dip below that things get sketchy. Here's what happens at 12psi on the tires
I have about 4 of those and they arent cheap to replace.
The other thing I noticed is that I was running a bit higher boost. Not sure if the loading was a little different because of the sticky tires but I was making 2-3 more PSI. My timing map is set to fall off over my target boost of 30psi. So after looking at the logs I discovered I was running 32-33 psi and only like 11 degrees of timing. There is a lot more left in this setup! - At least enough to get me to a 9
RRRRB
Nice.. I'd like to get the r230 in my s14.. I've already broke the R200 pinion.. I have a brand new set of richmond gears in my garage.. ready for when it breaks again.
You ever try and cryo or heat treat those output shafts?
So your running drag radials? 16's
Booztd 3
ET Streets on Rear Z32 TT wheels
Never had a set treated. If I can find an extra set I may have Drive Shaft Shop make a custom set out of 300M Billet
Darius
Booztd 3 wrote:ET Streets on Rear Z32 TT wheels
How much do you think they will charge for that? I was on their site and a set of "900 HP" shafts were $1,700.
Booztd 3
I was quoted a few years ago about 550 per side, but who knows what material cost has gone up to the last few years
RRRRB
Id be interested in a set of those.. maybe we could get in on a group buy or something...
You have any handling issues with the bias ET streets in the rear and radials in the front??
I just bought a set of tires and the guy at M&H was pretty insistant on not mixing them.
Did you install those Richmond gears yourself? Did you have to reshim the pinion diff etc?
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
good job man!
Largekid
Car: '96 RB S14 SE, '04 LS6 CTS-V
very nice andy!
74260zt
Car: rb26powered early 74 260z car
Pretty daym good for that ol gal (motor :biggrin: )
RRRRB
You ever try preloading? Your clutch drops look violent.. i wonder if it would help with the output shafts breaking..
s13RBpowered
Car: 1989 s13 RB25 powered
Yea, slip that clutch a tad to get the drivetrain parts pressure on them before you dump the clutch
