32bit Vista doesnt need 4GBs or ram that is major over kill considering you will only get like 3.2 to use.Unless you are running Vista 64 you will be limited.C-Kwik wrote:You might consider a RAM upgrade if your laptop supports an easy upgrade. It's pretty cheap and since your're running Vista, it might be advisable. I purchased 4GB for my HP laptop a month ago for $75 and recently, got the same RAM for my mom's new HP laptop for $50 (both at Fry's). Vista is a resource hog. I've never compared Vista to XP directly on similar systems, but looking at the resource monitor on my computers, Vista is taking a minimum of about 1 GB by itself.
I agree. I even said so in my original post.Nali wrote:32bit Vista doesnt need 4GBs or ram that is major over kill considering you will only get like 3.2 to use.Unless you are running Vista 64 you will be limited.
I would hope so. Vista is supposedly better at managing memory as well. To what extent each is? I have no clue. I was merely providing some specs as own/have access to 4 Vista systems with various specs to provide something to compare to. As I had suggested in my post, if cost is an issue, then run the game and see if RAM is an issue or not. And while I would think Crysis is going to be very hardware intensive with features and settings turned on/up, not all games operate in the same manner. Some will be more memory intensive than others.Nali wrote:Many people dont know that when a game actually starts running the amount of ram being use goes up only minimally on Vista. My PC runs at 940mb idle. When running Crysis Warhead it only goes up to 1.6 - 1.8. Is that to say Crysis only uses 700mb? No, Vista drops its usage substantially.
DOH! DDR3 notebook memory isn't quite as available or as cheap as the DDR2 I'm running. But a quick search netted this:marlin29311 wrote:I'll definatly see about the RAM upgrade in the future - I haven't really found many places that stock DDR3-8500 notebook RAM though, and I'm not a huge fan of having it shipped to me (did it once, the RAM was bad and it was a 2 month ordeal...not fun). But I'll certianly check out that vista experience index thingy. I never knew that existed....
Probably why most people build their gaming rigs as desktops. Espcially if cost is a concern. Most people buying laptops on a budget have to make some sacrifices.marlin29311 wrote:I also had no real choice in the video card, which kinda stunk. If i wanted something better (like the FireGL or something else) I would have had to buy the W series thinkpad, which was a crapton more...
I wouldn't worry too much about 64 bit yet. Although I haven't run anything heavy on my systems nor do I have any real 64 bit apps, there is no discernible difference. The only reason I chose 64-bit where I could is because it cost me nothing to do so and provided me with additional access to more RAM. The plan was to upgrade all my systems to Vista at some point as I enjoy using it on my work PC. But it kinda got sped up when my laptop completely locked up and wouldn't boot. Couldn't even restore it using the OE XP partition. And while I have my own copy of XP, my friend got me a copy of Ultimate for $50. It made the decision rather easy...marlin29311 wrote:32 bit vista - it's all that was offered at the time. I don't know if i'll have a big need for the 64 bit quite yet - but at least I have the option...i'll definatly see how stuff runs though before I go ahead and buy some more - I have 2gb now in 1 DIMM, and i still have a DIMM open.
Yea, this wasn't really built as a gaming rig, but more of something to replace my dead T42 from 5 years ago. I like the mobility of the laptop so I can take it anywhere, but I also wanted something pretty powerful as well.
Just thought I would update as of now...C-Kwik wrote:
Also, if you go to the systems folder in your control panel (classic view), it will give you a windows experience index number. it basically points out the measured bottleneck of your system. I think it actually runs processes to determine this so some of it might be based on running background applications and such. But either way, it might give you soem idea of if your laptop's performance might improve if you upgrade the RAM.
