SPL / KTS Adjustable Camber Plates
Allows for camber adjustment and ride height adjustment in front through upper mount (no need to remove wheels). Height adjustment does not affect spring preload. Fits KTS coilovers and most "JDM" coilovers.
SPL Rear Traction Rods - CHEAPER!
The traction rods holds the rear wheels in position relative to the chassis during acceleration and deceleration. Solid bearings and tubular construction reduces play/movement in this critical link. For best performance should be used with solid bearing spindle bushing and reinforced subframe.
Note: Adjustment of the rear traction rods together with the rear tie rods (Hicas models) or rear toe arm can also alter the geometry between the two two arms to reduce rear bump-steer. This should be setup by a race alignment shop.
Note: Hicas must be disabled.
Construction: Chrome plated machined steel16mm rod end ~8,400lb static load rating
http://www.splparts.com1-866-SPL-PART
