Pitts »
https://forums.nicoclub.com/pitts-u231537.html
Tue Feb 11, 2014 2:35 am
Earlier today I just bought a '84 NA. I bought it for $400 and all it needed was a fuel pump (which I've ordered from TRE). I'll be picking it up by the end of the month. Once it fires up (old pump is barely working), I'm hoping to not hear any valve tapping. 185k miles on the body and 122k miles on the engine. After the fuel pump, a complete tune-up is in store (with timing and a water pump). Eventually I will be grabbing all the necessary parts to do the factory turbo swap. Oh, and it does have a 5 speed with a stage 2 clutch thankfully. I'm expecting to have to replace the struts, hoses, and belts (the latter two will be done with the tune-up). I've been doing some reading and I'm hoping the hatch doesn't leak or at least that there isn't much, if any, rust. Maybe I'll get super lucky and I can just use a sanding pad on a die grinder and touch up the surface on any rust I approach. I do live in Montana and the previous owner bypassed and removed the heater core. That won't be a worry for me however simply because it'll be a summer only car (my DDs are both FWD).
After I do the factory turbo swap, I plan to upgrade to 30 way adjustable coilovers (the BC's on Z1), upgrade the rear diff, and do some chassis strengthening (3 pt roll cage, sway bars, and tower bars). Then I'll do some minor things such as a full 3" turbo back exhaust, better intake, boost controller, intercooler, upgrade the necessary fuel components, lighter driveline, and probably a few more things. I just want some good power that I can DD, walk on the Mustangs and some Camaros here, as well as go for a spirited drive and smoke some tires.
I'll take some pictures and upload them once I've gone through the car and inspected (clean actually) it.
Has anyone used the Quaife diff that Z1 has on their page?
Thanks.
