Aven »
https://forums.nicoclub.com/aven-u152240.html
Sat Jun 05, 2010 5:39 pm
I know that they messed up two of the lines for mine in the manual. So, you might have it just like it shows, but it not be right. Know anyone with one that runs in your neck of the woods? A side by side comparison might help.
You might want to clean your throttle linkage. If its sticky it might not be allowing the butterfly to close all the way. Without starting it, pop the air cleaner off and look at it. It should be closed. If it isn't, clean the linkage and depress the accelerator all the way to the floor. That should close it.
