Timmbo wrote:I can't remember if the steering wheel illuminated on the '07 and earlier models. Hopefully someone here can let you know.
On the DVD screen, the '07 and older models did have an issue with lack of support for the screen. Nissan/Infiniti had a TSB where the dealer was instructed to install a bracket to reinforce the DVD screen.
If you have the AUX capabilities the jack should be located right near the stereo. Did you check the owner's manual?
The dealer said the steering wheel doesn't illuminate which is surprising because if you haven't memorized the layout by feel, then you have to turn the light on at night to see it which is distracting.
Regarding the DVD, the dealer installed it post sale when it was new by one of the dealers aftermarket installers. It looks very professional, but rattled when open. I got the car back yesterday and they had the installer rework it and said a wire had been loose which cause rattling. They redid it and it is much tighter. I think we are going to be fine with it. Since it was done post sale, the TSB would not apply to this, but regardless, it is pretty tight now.
I did notice a rattle on the sunroof shade before I brought it in actually on my way to drop it off for service. If the shade was even partially open, it rattled like crazy for about 10 minutes and then couldn't get it to do it anymore. Since I got it back, it seems to have been fixed and could have been attributed to the loose wire that up in there. I would recommend troubleshooting all of the rattles and then taking it in because if you let them do it, they won't try that hard and most likely won't hear what you hear unless you tell them how to replicate the noise. It is a tight car and should be so if you experiencing anything less, then take it in. Mine is much better now.
Regarding the aux, when I press the mode button on the steering wheel a few times, it will eventually say/switch to AUX mode which tells me that it should have it. However, I don't see the aux jack anywhere in the vehicle and the only place that has an iput of that size if the headphone jack above the 2nd row controls. What am I missing? I couldn't find anythng that reference the AUX mode in the manual in general.
