joe603 »
https://forums.nicoclub.com/joe603-u34652.html
Tue Apr 12, 2011 5:29 am
Welcome to NICO! Make sure to look around the site for tons of info and mod ideas!
To break in your car properly, here's what I recommend.
1. For the first 1200-1500 miles:
-Do not rev the engine past 4k
-No racing off the line or hard starts.
-Do not use cruise control for extended periods of time. (The engine should not stay at the same RPM for any extended period of time.)
-No hard stops, the brakes need to set. (If you have too, you have too...stay safe!)
2. Change the oil at 500-600 miles. If you have a free oil change, now is the time to use it. I always replace the filter when I do an oil change...its cheap enough. This will clear the engine of any break-in oil. Not necessary to use synthetic. Still follow break-in procedures!
3. Change the oil at 1200-1500 miles with a good synthetic. I recommend royal purple oils.
After the second oil change, drive the car like normal!
