ShaneZ32 wrote:Hey all! I just picked up my first Z yesterday and Love it! However.. she doesn't run anywhere near right.
Checked ecu Diagnostics, LED doesn't come on at acc position even after turning the screw.
Issues are that it runs super rich, and idles really low (around 200 rpm). When I bought the car yesterday it had a bad miss. I replaced the plugs and it fixed it. I have checked for vacuum leaks and checked the MAF. The injectors are all reading correct ohms. Possible bad computer?
First off, the key needs to be in the on position, but car not running. Acc position does absolutely nothing.
Still could be a possibility on the ECU, but also could mean the injectors are just gunked up from sitting for so long, bad gas, bad filter, bad fuel filter, etc.. Have you done any maintenance on the car?
Im not telling you not to do the swap, but they get expensive fast. Like I stated in another post, it cost me 5k with parts and labor, and I found a hell of a deal on a conversion with a 5 speed swap. Most guys can spend near 10k. Just make sure you do your homework on the front clip, whether its JDM or USDM, so many horror stories on JDM ones.
