BBISHOPPCM »
https://forums.nicoclub.com/bbishoppcm-u54071.html
Sat Sep 27, 2008 1:32 pm
What you experienced isn't entirely abnormal. I say this because you experienced something a little different than the usual...
Normally, if the wheels slow down too quickly, the transmission compensates for this by throwing it into "first gear." This is because unlike a traditional automatic, the CVT uses a steel drive belt that rides on two adjustable pulleys. In order for this system to work properly, the pulleys need to adjust the drive ratio according to the speed sensors. When the speed sensor sees you traveling at 50 MPH little throttle input, the transmission will automatically position the pulleys to give you a larger drive pulley and a smaller driven pulley. The same works in reverse; if the car suddenly slows down from, say, 30 mph to zero, the transmission compensates by forcing it into a much lower gear, if not the lowest. What the Versa has is sort of a "panic" or "limp" mode; this is usually activated if the ABS system kicks in, or of the wheels suddenly lock up in a panic braking situation. This will cause the transmission to hold the low gear position for several seconds after a panic brake incident. This is normal, and I believe it is designed to help slow the car down to assist the braking system. By throwing yours into reverse, you may have confused the system to a certain degree. As long as it's working fine now, you likely have nothing to worry about. This system saved my life last winter, when I suddenly hit a patch of ice.
