1. Probably need new pads, and should probably have rotors checked while you do it.2. What makes you think this... Does it pull?3,5: I think your speculation could be correct.. Check the heat shields, but its possible the cats are clogged..4. Doubtful, but you do need ot add a transmisson cooler, esp down where you are...Black95Q wrote:The driving experience has been pretty good so far... besides a few minor concerns, 1. like the brakes squeak a little 2. and it needs an alignment. Also I notice that the starter seems a little too loud and it takes too many turns before the engine fires up.3. Another issue that I noticed is that I feel heat from underneath the car after driving for 10-15 mins. I don't hear any leaks in the exhaust system and the engine doesn't run hot according to the temp gauge. After driving for 20-30 mins I start to even feel the heat on the shifter while I'm driving. 4. At first I was worried about the transmission, but it shifts smooth and without any problems. 5. I'm thinking that this might be the cats running too hot or something but I have no clue actually. Any information or speculation on this issue will be greatly appreciated.
Im not concerned, in a few weeks we'll find all kinds of neat posts about fun things he discovers...gniknave wrote:Welcome Welcome! Lets see those pics too when you get some!
Wes, you don't get to make this newbies heart sink to his stomach with the chain guide story j/k
Thanks for the welcome and the info.2.The car definately pulls a bit to the right, if I let go of the wheel I'd be in the next lane in 2 seconds 3.About how long do the stock cats last before they start to clog up?4.So these cars dont have a stock trans cooler, do many people add this?elwesso wrote:Welcome!!!
Thank you, thank you. I should have some pics up this weekend.gniknave wrote:Welcome Welcome! Lets see those pics too when you get some!
Thats strange. I wouldn't mind it if I still lived up in Maryland, but it's hot down here in South Florida, I don't need any more heat lol. I mean its not that bad if I turn on the ac, which I try not to, but I dont like to waste gas.JoshIsSciFi wrote:I just thought I'd add, I don't know that it could be the cats or heat shields... because funny enough, I get just a tiny TINY amount of heat into the cabin with mine, and I don't have any cats OR heat shields now lol
Thanks for the heads up Fred. I definately don't want to sleep on any of the minor issues I see with the car so they dont develop into major ones. I'm sure I'll find plenty of useful info on this forum...thanks guys.PalmerWMD wrote:Black,Congrats on your new car, IMO one of the BEST used car buys out there!
Everything that was mentioned, applies to all other cars, being hi-end your Q is a just a bit more, but its not all that much more, than maintaining any other car to a high stanbard.
Do the preventative maintenance suggested and <save> real $$'s long -term.
Have thgat heat issue looked into, if your cats are clogging it could start affecting other systems badly.
transmission cooler is not expensive; $45-80 depening on whereand what kind you get.You can DIY this, its not all that hard, or just pay someone 1.5 hours to do it.
It <will> help your transmission last longer.
Also the common spource of possible clogged transmission fluid lines in this car, in the factory heat exchangers, will be eliminated that way potentially saving the transmission in yet another way.
Q's are very reliable cars...its all in preventative maintenance.
Fred..
