Hi all, anyway, I recently purchased a 1995 Q45 for a winter beater, and I had a few questions....
maybe someone could answer...
I have a "NICO" ecu with a reman' sticker and 'stage II - closed, stageIII - open' ,
complete with a glovebox mounted switch run out the diagnostic hole in the ecu case.
My Q has the 'shudders'..... occasionally
with the NICO ecu I get code 46 - secondary throttle sensor... could this be the result of using a Traction control ECU on a non traction control Q45?
with the original oem ECU (the kind previous owner had both) I get;
code 12 - MAFS
code 34 - knock sensor
^obviously knock sensors and harness... rather cheap endenvour, to be done soon.
the MAFS I cleaned out thoroughly and the box/snorkle/new filter..
plugs were changed, and coilpacks visually inspected for heat stress, (I also have an SR)..
oil change w/1L flush plug open
fuel filter replaced
but code 46...?
I find it odd that there is no overlap in codes between ECU's....
I'll see if I can post up a pic... another day from another computer.
Totally unrelated, but anyone notice this floating around the interweb..?
http://www.terra2imports.ca/import-japa ... 091458.htm
