VimyJ »
https://forums.nicoclub.com/vimyj-u238.html
Tue Feb 18, 2003 6:42 pm
The 93 J30 has the VG30DE Nissan engine. The timing belts on the 93 (and perhaps early 94) had to be changed at 60K miles (100K kms). The new belt would be the improved version good for 105K miles (160K kms). On later J's that came with the new kevlar belts, a 100K mile service has evolved that involves changing the timing belt as well as WATER PUMP, HOSES, BELTS, THERMOSTAT, IDLER PULLEY, CAM SEALS that can all be done at one time. Please do a search on "J30 timing belt" etc.
Parts can be had more cheaply (click on one of the ads here) and a good independent shop will give you better labour rates and better service. These are pretty well known Nissan engines that were (in different setups) used in 300ZX's, Pathfiders and J30's.
