The first would be the front cab mounts they've rusted completely through about a half inch all around the mounting bolt in the cab floor, not sure if i should just weld some sheet over the gap (i know it wont be structural) or do they sell floor pans for these trucks like the older Chevy's and Fords.
The other big one right now is the... not sure what its called i think its called a tension rod mount? or compression rod mount ( 8 to 10 inch long rod flat on one end two bolt holes other end goes through bushings that compress around it as you tighten it to the frame helps keep the lower arm stable, the outer washer rusted out and fell off some time ago and the frame mount is all wallered out so any suggestions on how to fix it would be appreciated ill try to get some pics tonight and post them, I'm still new to forums and posting on them. thanks for your time and help
