ashibah83 »
https://forums.nicoclub.com/ashibah83-u48930.html
Thu Nov 26, 2009 6:59 pm
suspension/brakes first, they will have a MUCH more overall impact on your car, your handling will improve, your looks will improve, your brakes will improve....and have you ever driven a 300whp s chassis on stock suspension and brakes.......it is NOT fun...
decide what your goals with the car are, you know DD, weekend track warrior, dedicated track slut,ect......
if your going the dd/weekend warrior route then start off with
-GOOD spring/strut setup(look for ground control/koni), OR go with a decent entry level coilover (KTS, Stance, PBM, Tein there are too many options to list)
-Either a master bushing kit(Energy Suspension) or aftermarket suspension arms(depending on how low you want your car, the lower the car the more that is required to correct the alignment)
- Chassis stiffening (again, depend on how far you want to go)
-Brakes......ok to be perfectly honest i HATE my stock brakes, i use my car as a DD/occasional track car, and the fade and lack of stopping power is bad (power slot rotors and EBC green pads, and please no one come in and bash me on this saying that my tires are probably junk, first set were Falken Azenis RT-615's, now they are Hankook Ventus V12 EVO K110's, and the difference on stopping distance is negligible). I would AT least go with Z32 fronts, Z32 BMC, and good pads and rotors on the rear, there are many options available only deterimed by your budget and needs
-after brakes should be wheels and tires, make a good decision with this, good widths and offsets can be fitted on an S chassis without much trouble, and tire selection is HUGE, do some research on this one, a good tire will yeild MUCH more than better lap times and stopping distances, just remember that YOUR TIRES ARE THE ONLY PART OF YOUR CAR THAT ACTUALLY TOUCH THE ROAD, so please dont skimp here
- A GOOD SEAT, the stock S chassis seats are a joke for anything more than sunday crusing, so a seat will go a long way in comfort, saftey( please get on that is rated and approved for track use), and interior looks
- after all that go either Aero, or power whichever you want depending on your goals
there ya go have fun
