evildky »
https://forums.nicoclub.com/evildky-u13100.html
Thu Oct 12, 2006 8:01 pm
the chassis code is "S130" which denotes all 79-83 280ZX's
the steering racks normally leak due to boneheads using power steering fluid, the correct fluid is Dextron ATF which is much thicker and isn't as prone to leaking out, depending on how bad you leak is you might try draining the system and refilling with ATF also if the banjo bolts on the rack have been off or the hoses replaced with aftermarket hoses try replacing the copper washers with OE washers, I had an issue recently where the replacements were too thin which caused the bolt to bottome out without sealing the banjo fitting
and for your head bolts, summit or any speed shop should ahve the ARP head stud kit for about $130, other than that your stuck with the torque to yield OE's
