480sx »
https://forums.nicoclub.com/480sx-u50548.html
Thu Apr 09, 2009 4:08 pm
I bought a new oil pan for my build, and installed a bung. Figured id share a bit. Also added a EGT probe bung to my AMS manifold.
So i used the JGS bung, and a brand new OEM oil pan($110).
First, as i did with the last pan i made, i wanted to create a downward angle for the oil to flow through. This was done with our mill. Its actually a pretty cool shot cuz the mill was spinning when i took it.
This is the end result with the JGS hose barb fitting, and the pan that the work was done on in the background.
This is the bit you really want to use for sheet metal, it gives you a perfect cut every time. Drill a tiny pilot hole or use a spring tool to punch a center mark, and your set. Hole drilled. I picked a location thats probably to far forward for a non modified AC bracket, but i dont ever plan on running ac on this car so i dont care much. This spot also allows me to use all the bolts in the oil pan. The other one blocked a bolt hole, but allowed me to keep AC and was perfect. The old one never leaked either but w/e.
My bung is excited! Well in all actuality it was takd into its final place. Two beads were placed on the outside of the pan-bung for strength. The sealing bead was done from the inside.
This is the inside of the pan. Looks pretty horrible lmao, but you have to know what to look for. The 'ugly' parts is from the penetration from the outer welds that were done strictly for extra strength. The inside lip weld was the 'real' weld that seals it. I cleaned up the bubbled coating and its good to go.
Moving on. So iv been wanting to have an EGT probe on my car forever. For this build, i went ahead and modded my AMS manifold so i could run one. This was as simple as drilling through a 900 dollar manifold and welding a bung to it...
Cylinder number 3 runs hottest on a Ka im 99 percent certain, so that was my choice for the bungs location. It took us a bit to figure out exactly how to mount it, but we came up with a location and, well, had to start somewhere.
Heres my new 900 dollar manifold.. This was done with a spring tool center punch, then just normal drill bits.
The next part was a bit tricky. We had to make the little bung fit pretty snugly with the pipe. When tig welding, you dont want a gap thats bigger than your filler rod, and thats what we ended up with. Here is the bung in its final position tacked on. Somehow i didnt get a finished pic, ill get one up eventually. The weld turned out perfect, even though it was a really difficult place to get the torch in.
The root of the weld. It might be a bit difficult to see. You can see a lot of AMS's roots, which are generally perfect. The key when tig welding stainless steel is back purging. If you dont backpurge with argon, the molten metal reacts with the O2 in the air and ignites it causing a, bad weld. The root will appear black and burnt, with pieces dangling out on the inside if you dont do it right.
