Hello all! Just wanted to introduce my self and my project as it now has life...somewhat...I picked up a S2 RB25 motor/trans from RawBrokerage here about a year ago and due to school/work etc haven't gotten a chance to really get a crack at it till now. So for about the last week or 10 days I have been working like a mad man and I have pulled the KA, put in the RB and trans etc. and have begun my attempts to start it...to little avail. So here's the rundown of how it currently sits (and yes I understand there's more I need to hook up to expect it to run perfectly):
1994 S2 RB25DET from an ECR33
Mckinney Mounts
Shaftmasters Aluminum One Piece Driveshaft
Greddy plenum with RB25 TB adapter plate and S14 throttle cable
S14 auto OE radiator
ISIS oil filter relocation kit
Wiring Specialties premade RB25 to S13 harness (M/T)
New NGK BKR5EIX-11 spark plugs
Spec Stage 2 Clutch and PP
300ZX TT fuel filter
Braille B2317R 17 lb Battery
Raw6 intercooler
Walbro 255 fuel pump
OE RB25 MAF (Maxima equivalent)
Flex-a-lite 412 pullers
Now, for what isn't hooked up that is a duh:
Intercooler piping
IACV hose(the one from the IACV to intercooler piping)
BPV
exhaust (yes, I am straight piped out the manifold as it sits now haha)
power steering and lines (need custom ones made)
and I think that's it...
So here's where the story continues, I got all excited today and began trying to start it. It cranks very hard and occasionally pops. So, I got some starter fluid out and it fires up and runs until it's out of starter fluid. Did that a few times till I figured it was a fuel issue. So, I switched back to the OE fuel pump and tried a few more times. This round, coupled with some mild turning of the CAS, it decided to fire up and IDLE! BUT, only for about 5-10 seconds and then it would slowly die. I have since switched back to the Walbro pump and get the same results. This was all done with the MAF disconnected because all attempts with the MAF connected failed miserably. Any addition of throttle kills it almost instantly. Also, I have a check engine light on but I'm not seeing any codes from the ECU.
So my question is, are the things listed that aren't hooked up absolutely necessary for a somewhat smooth idle? In my N00B excitement am I on the verge of destroying my motor by trying to start it in this state? I don't intend to try any more until I get most of the listed things hooked up/installed but I thought I would pick the brains of experience on here.
Here is a link to videos of the progress:
https://picasaweb.google.com/turbotuner ... 5Progress#
Thanks a ton for any help!
Eric
