deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Wed May 05, 2004 7:46 pm
Well, the slack on the one side of the chain is because when your engine stopped, the camshaft rolled over a bit more than the crank. Turn the engine a little bit in the clockwise manner to put that slack on the tensioner side. But anyways about your problem, unfortunately the ka24e has major issues with the timing chain system. Was a new timing chain used? Was it an aftermarket kit? A lot of the chains provided in aftermarket kits are poor, usually 06B type (vs. they beefy stock 06E chain). These stretch very quickly and in the ka24e setup cause problems. Roll your engine over to put the slack on the proper side, then look down at your tensioner cylinder with a flashlight, if you have like 1/2" or more cylinder showing, the chain is stretched. If it doest appear to be stretched, the tensioner may be weak, not holding much oil pressure. Have you checked your oil pressure across the rpm range? and when the problem occurs? this may be able to tell you something.
Start up rattle is one thing, but running rattle is a definate problem
btw. check for other things rattling on the engine, they can throw you for a loop. like the exhaust manifold sheild, etc...
