71-521 »
https://forums.nicoclub.com/71-521-u110104.html
Wed Dec 31, 1969 5:00 pm
There was a posting on another board about the 320 shift patterns...it was for the left hand drive versions and not the Aussie types...here is that posting:
[quote]HI,
The 62-64 320's came with the Column-shifted 4-speed.
The late 64's and 65's, and the few "66"-320's (hold overs, or late
arrivals) all had the floor shifted
4-speed, similar to the 410 4-speed, but different from the J-13 66 520
(late) 4 speed.
I have the laterJ-13 4-speed in my 66 520, but there is a specific VIN, that
before that VIN,
it has the same as the 320 4-speed. As for shift patterns...
> 1st is all the way forward and up,
> 2nd is all the way forward and down
> 3rd is all the way back and up,
> and 4th is all the way back and down
> reverse is a tricky little bugger...
pull the shift lever towards the passenger side of the truck, push it all
the way forward and
drop it down as if you were going into 2nd. It is a bit of a trick to get it
to shift correctly,
depending on how worn your linkages are.
Hope this helps, Garry k[/quote]
I hope this helps you!
L8r
