karay240 »
https://forums.nicoclub.com/karay240-u11860.html
Mon May 03, 2004 3:48 am
Yea, I know how you feel about the STB not fitting. I recently (finally) got my engine and transmission mounts in my car, and found out that the STB no longer fits. I took the cam cover off and shaved the letters (twin cam 16 valve) off, and painted it w/ heat resistant paint. It worked out better than I could've possibly imagined. There still is minor contact that I will try to remedy by placing a thin sheet of metal b/w the STB and the strut towers.
Another thing that rubbed was a screw that bolts the fuel line to the intake manifold. All I did w/ that was remove my screw. There are a couple more holding it in, and I seriously doubt that it's going anywhere.
I also dremmeled the underside of the STB where there was contact. Yea, dremmeling a STB might reduce its structural integrity, but I think it's a heck of a lot better than rubbing against the cam cover. Now that's REALLY annoying. It was like having the engine solidly mounted, w/o the benefits. lol.
I do love the mounts, though, and would do it again in a heart beat. Probably not by myself again, but w/ a little help.
I didn't notice any more vibration you mentioned, though. To be honest, I noticed a reduction in vibration--especially whenever you gas it, the car just seems to rev up, instead of rattling the occupants. I think this, partly, has to do w/ the fact that my stock ones were pretty worn out. This entire post was written under the assumption that the mounts you installed were the Nismo mounts. I've never heared of other moutns raising the placement of the engine. If you got polyurethane mounts, or URAS type mounts that are just a thin sheet of rubber on a aluminum block, then I understand the vibration.
Anyway, the easiest fix for the STB is probably going to be to get a thin sheet of metal, and sandwich it b/w the STB and the ST. Good luck on trying to make it fit. . . and don't get a sheet that's too thick. the bolts are only so long, and you will need to have adequate thread, and the STB may have a problem clearing you hood.
Good Luck,KennyUnderground Motorsports
