NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Tue Apr 26, 2005 2:00 am
did you pull the valve cover to be sure your marks were on the money? It still sounds like your out of time ,and worse that your so far out of time you may have tagged some valves[based on the low compression readings coupled with noise.] pull the cover off and bring it to TDC by hand,check all your marks and be sure they are correct. if they are all on have some one bump the starter and watch all the cam lobes, make sure they all turn, It is possible a cam shaft snapped. I know, not what you wanted to hear.
