ka-t 300 »
https://forums.nicoclub.com/ka-t-300-u71940.html
Wed Feb 17, 2010 1:16 pm
Well it was still acting sort of lean but was running good then heard some squelling sounds . thought it was blow off valve started to replace that while i was at it checked shaft play on turbo and uh ooooo loose , looked in the compressor housing and could see where the wheel had been rubbing on the housing. so checked oil feed line for restiction and it had a piesce of rubber stuck in the restrictor, so what we have here is oil starvation for the turbo. well as some of you may remember i was looking into ball bearing turbos about a month ago, didnt get one how ever i have replaced the turbo with a new one. while i had the down pipe out i noticed that there was carbon marks leaking through my v-band joint witch is is located right before my 02 sensors , so in short part of my running lean problem was probly due to that exhaust leak right before my o2 sensors.
Any way wanted to point that out as some thing to check for on lean issues. got new turbo blow off valve installed fixed exhaust leak , connected alt. connector , broke it in for 500 miles and boosting 18 psi now.
thats true ka-t = blood sweet and beers (and money) lol.
I love it though its running great. trying to fig. out how much boost you can run with just 93 octane though ?
