ditto! good job.G_whizz wrote:Excellent write up and pics!!!
fatire_mtb wrote:No voltage stabilizer required with the grounding gear kit.
Aside to the ground wire kit. I was talking to a friend of mine who used to be a F-16 mechanic and he told me they have similar grounding kits. Therefore, I now have the same capabilities as an F-16
Finally, something for our cars that comes from Canada and is decent quality! SHOVE THAT UP YOUR DUTY, CUSTOMS!!!fatire_mtb wrote:I paid $150 for the kit and shipping. GroundingGear is located in Canada so it takes a while to get here (I live near Atlanta and it was 12 days to arrive).
I sent Gord an email asking him about what the full line of products are and the cost for each. He was real informative about how the various kits were different and the added benefits of each kit.
1 more questions fatire... how tight did u tighten the nuts?.. as tight as you could get it? (using all of ur muscle to get it tight)..fatire_mtb wrote:-did you jack up the car? Yes, you need to lift up the front end for a proper isntallation
-how tight did you tighten the nuts? good old craftsman socket wrench
-you know that one green piece that holds that one pipe near the right side of the strut bar spot.. did you take it off?.. in the pic it looks like you did.. i'm pretty sure you have to take it off.. the CS Strut won't allow me to keep it on.. it should be ok to take taht green piece off right? Yes, I took it off and then secured the pipe that was attached to it to the strut bar with a large zip tie
I've got a 03 6MT and did it..I can definitely tell the difference in response. I didn't have it dyno'd before and after to see the actual gain, but definitely quicker throttle response. I've got a lightened flywheel as well so it alwready rev'd quick, but I could still tell that it helped.joe603 wrote:Has anyone done a grounding kit for a 6MT? Any benefits?
Yes, I just used good ol' elbow grease. I couldn't find the spec ft-lbs to tighten to so I made it as tough to get off the next time as it was the first. Real scientific I know.illmaticxdrp wrote:
thanks for the reply!
