e_c »
https://forums.nicoclub.com/e-c-u14217.html
Thu Feb 02, 2006 6:05 pm
i found this on another forum, i might also give this a try in the coming weeks, if i do i will include pics
Factory headlight position is controlled by a 'timer' circuit behind the driver side footwell (passenger side on JDM 180sx's). Basically the unit controls down movement only!!! If you unplug the unit you can still raise your lights but not lower them (probably designed as a safety feature if the timer unit ever failed)
The pink wire on the timer loom is 0v when the lights are down and 12v when the lights are up. After being open, the factory timer unit keeps this wire at +12v until the lights retract - the unit then cuts the power keeping them down.
The pivot unit intercepts this pink wire signal after a time determined by a potentiometer of some kind. So when the dial is at 80% the pivot unit cuts the power after 20% of the factory timer period - keeping the lights at 80% open.
This is exactly the same as the cheap-as DYI method of installing a manual switch and flicking it when the lights are at a certain point. I believe the pivot timer uses a standard 555 timer chip and a BJT amp with a potentiometer to make a variable time delay switch.
Incidently the pivot timer doesnt always work perfectly - it seems to set the lights at different heights from what you set the dial at. It will take some time to work out the quirks. The manual popup button next to the steering column also seems to screw with the settings.
