float_6969 wrote:The knock and CAS are separate codes, one won't cause the other to show up. Also, the failed knock sensor doesn't start the failsafe either. It is just reducing timing (and so power) I know this for a fact because when I first installed my CA, I didn't hook up the sensor. The car ran OK, but it was down on power. Once I got the knock sensor hooked up, it ran much better.
What does this mean exactly? Does it switch to the Knock Timing Map for timing, but stays on the Normal Fuel Map for fuelling? Or a constant timing retard?
It would be nice to gain some power only by connecting a wire and a piece of shielding.
But if I'm running with retarded timing now, that would mean my lag will be even worse after I fix this, and it's barely tolerable now as it is...
