foxboy63https://forums.nicoclub.com/memberlist.php?mode=viewprofile&u=113&sid=43caff686b0c8b64f418026612c3af6dNew member that needs help!Sun Feb 05, 2012 4:17 pm
Postby
foxboy63 »
https://forums.nicoclub.com/foxboy63-u198131.htmlSun Feb 05, 2012 4:17 pm
Hello everyone! Greetings from cape breton nova scotia I have just purchased my first nissan pickup for a cheap $500! Its a pathfinder V6, with a 2 & 1/2 " lift kit, 30" all terrains, and a 5speed. everything works nicely so far! But, after getting it out of 4wd , I found that every time i took power off the rear axle [IE: shift, let off the gas, etc] The truck seems to crab walk? The rear kind of drifts off to the left... But this only happens when i let off the gas.. when i press the gas back on, the truck straightens back out... The frame has seen better days but it is still solid, and has been reinforced with new steel welded in.. Here are some pictures of it if your curious how it looks.
Postby
foxboy63 »
https://forums.nicoclub.com/foxboy63-u198131.htmlSun Feb 05, 2012 6:46 pm
Okay, I will try to do so tomorrow. I also found out from my friend who did the lift kit on the truck, that the rear shocks we're too short and kind of bottoming out backwards? So instead of being fully compressed, they're being fully extended... And the truck is a 4x4 with a 5spd manual, so i would need to overfill the transmission with gear oil? I am a very novice mechanic, hence why i am taking the automotive trade offered at my high-school.
Postby
Towncivilian »
https://forums.nicoclub.com/towncivilian-u161382.htmlSun Feb 05, 2012 6:51 pm
You must use API GL-4 gear oil only. I listed some options in the thread I linked. If you haven't done so in a while, perhaps just do a complete drain & fill of the transmission and be sure to put the correct amount in.
Sorry, I don't have any advice regarding the suspension. Like I said, you may want to register on NPORA and ask there.
