back to the Q club!
12 years ago would have been back in the Yahoo board days... what was your user name then... just curious - I spent quite a bit of time there.
The third motor mount (a/k/a transmission mount) is a common cause of vibrations. You will usually feel it most in the seat bottom when starting out from a stop while facing up an incline. Old exhaust mounts and hangers also send more vibrations to the car.
If it hasn't had an injector flush recently, and the plenum hasn't been off since 80K then it could easily be due for knock sensors again (assuming they were changed at least once by now). Those can definitely cause dead spots during acceleration and are not "check engine light" items.
If Byron is still at the S. Cobb location (or any T3) it might be worth your time to pay him for an hour of his time to give it a good inspection... I suspect he is one of, if not the most knowledgable technician around for the first generation Q.
Heath
