I previously had a 98 QX4 for a couple years, just picked up a nearly identical 98 QX4 and planning some OEM+ upgrades after the routine maintenance. First thing on my mind is a "slight" lift to replace the aging suspension. It's got less than 160k miles but it's something I always wanted to do with my last R50.
I've watched all Tyler's videos, I've scanned this forum and NPORA. I've decided I will stick with the tried and true rear setup of 9447s and 5100s.
1) First question is regarding the front. I do not want to risk topping out with AC springs. This will be a daily grocery getter mall crawler, but perhaps if I end up building a somewhat capable machine, I may want to take it off roading - NO ROCK CRAWLING for the foreseeable future though! Don't have many rocky trails near me. I mostly like the look for aesthetic reasons. I do not plan to go higher than 2".
So I have saved links to the 3 OME springs, light/med/heavy. My goal would be for as close to a level ride as possible to match the rear. Not a fan of the raked look. I have no plans for anything heavy other than a front bumper/grille guard (stock looking style). Which springs would best be suited to match the rear lift? Or should I do a small spacer lift from SF Creations if I don't really plan to go off-road with newer OEM spec springs? Or in combination with the OME springs?
2) Second question is regarding the front struts. I will be getting KYB. I see on RockAuto they have the GR2 Excel G-strut. This is what I need correct? I see GR2s elsewhere like 4x4 parts but would prefer not to buy from them, they look slightly different in the pictures.
3) Final question is what else do I need? After watching one of Tyler's videos he mentioned a missing link? His youtube link led to a dead page. Will this be needed for the height I'm aiming for? Other items I'm thinking of changing out but would like some input on part #s or sources to purchase:
- missing link aka control arm brace
- all the bushings
- bearings
- trailing arms
- control arms
- camber bolts/alignment kit
- should I get new CV axles since I don't know the condition of the current ones?
- will I really need manual hubs?
