New Member/ Nissan Pathfinder giving me headaches
psanchez0528
Car: Nissan Pathfinder LE 3.5L V6
I recently came back from mechanic where he discovered my Accelerator Pedal Position Sensor has gone bad.
I look up this part and I am looking at $240 just for the part and I am freaking out hoping you all can suggest a cheaper fix. I have yet to visit a junk yard to see if I find one for a reasonable price so I can here in the mean time, hoping to get some ideas from someone who has gone through the same
:bs:
psanchez0528
By the way, I own a 2004 Nissan Pathfinder with a 3.5L V6
psanchez0528
Here is the part number. If anyone can help me find it elsewhere for cheap, I would greatly appreciate it.
http://oem.nissanpartsdirect.com/oempar ... 5W91A.html
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Moved to Pathfinder Forum.
The cheapest one I've found is still pricey:
https://www.factorynissanparts.net/oem- ... 180025w91a $219.39
You might have better luck with a junk yard.
yeldogt
Car: 02 Pathfinder 4X LE (X2)
Is there an aftermarket source ? It does not seem to be a high failure rate part -- so going used may be an option if you can do it yourself.
I'm always reluctant with some sensors going aftermarket -- just went through this with my ABS sensors. With the age of these cars now -- anything is a possibility.
PathyPop
Car: 2003 Nissan Pathfinder LE 4x4
There's usually 4 or 5 and sometimes more than a dozen R50 Pathfinders and QX4s at our local pick-your-part (LQK), with whole pedal assemblies for ~$30. Should be fairly easy to get used.
Rockwood
Car: 2002 QX4
During this time period the Altima shared quite a few parts with the Pathys. For instance, I have a replacement light switch on my steering column that came out of an Altima. So if you take time to check, you may find they are the same part. Altima parts are cheaper in most cases.
Here is an Altima listing on Ebay:
https://www.ebay.com/itm/02-04-Nissan-A ... :0&vxp=mtr
So if the part is visually identical, it is likely the same part. The part number changes because the Altima has a different ID in the Nissan system than the Pathfinder.
It will probably also save money at the wrecking yard if you ask for an Altima part.
If you try this idea, let us know the answer!
