bblack23 wrote:Ready to get the ball rolling! Im putting together a little parts list and this is where I am at right now. Any brand ideas, parts you would recommend, chime on in.
SR20DET S14
Good brakes, rotors, stainless brake lines.
Coilover system - Adjustable from the shock body.
Camber kit.
Suspension bushings.
Rear sway bar.
Tension rods.
Tie rods.
Toe links.
Light weight wheels / racing tires.
SR20DET S14
Wiring Specialties Harness
Ton of good options here. I would recommend upgrading the calipers to the typical 300ZX front and rear. Along with this is a 5-lug conversion which opens up your wheel options.
This really depends on what you want and how much you want to spend. If you want to go the cheap route. I would go with Feal or Fortune Auto (if it were me, I'd do Feal if going the cheap route). If you want to spend more to get a better product, either a custom Koni/GC setup or a set of KW clubsports would work awesome, but this is the $2000-$2500 option, ha ha. The previous options are half that.
Camber kit.
Typically, when you get a set of coilovers it comes with the camber plates up front. For the rear; a set of SPL or GKTech rear upper control arms are good options. SPL is american made, which is nice. GKTech is Australian. Most of the cheaper and numerous stuff is either out of Taiwan or China (same with coilovers and most other cheaper 240 parts).
This depends on if you want solid mount, spherical or just the polyurethane stuff. SPL will have a ton of suspension options, anything they make is fantastic. Check them out. For the poly stuff, the typical Energy Suspension is fine.
Rear sway bar.
Whiteline or Progress or both good options here. There are others too.
Tension rods.
SPL or GKTech
Tie rods.
SPL or GKTech (or OEM / Tein for the inners)
Toe links.
SPL or GKTech
Way too many good options to list here, but try to stick to credible wheel MFGs and definitely check wheel weights and manufacturing before ordering. Best bet is to post up a few designs you like and ask. I could sit here all night on this, ha ha. I just bought a set of SSR GTV-02s myself, there will be an article on the NICO homepage in a couple weeks about them if you like those
As for tires, I usually like the 200 treadwear stuff for fun street driving. Dunlop Star Specs, Nitto NT05, BFG Rivals, etc etc. Not the most fantastic for rain, but they do ok there too. I just got Nitto NT01s myself, but those are not great tires for any kind of daily use, haha.
I'll add for the radiator, I'd recommend getting a Koyo. It's the best budget radiator that doesn't suck. I've had Mishimoto and friends have had Godspeed, those are less than ideal to say the least, ha ha.
