New member-need help with headlights
Hockeyref
Car: 2000 Maxima GXE- 5-spd manual
Progressive Springs (lowered 1.5 inches), KYB shocks, front strut brace, rear anti-sway bar, cold air intake
I did a search but could not find the answer. I have a 2000 Maxima with a headlight issue. Being in Canada it has daytime running lights which work fine, the right headlight will only work on brights, and not on the regular setting. I already replaced the bulb as well as the fuse and it made no difference. Any suggestions?
I'm guessing it's a switch issue... fairly common.
Fortunately, it's not hard to swap out. Grab one from a junkyard and see if that helps.
Hockeyref
Thanks for the suggestion
Chrisman287
Car: A32
Swith the passenger/driverside bulbs and see if the problem still persists on that side. If it does, then it's most likely the headlight switch/stalk. If the problem switches to the other side then it's a bad bulb.
