I just purchased a 1992 G20 Infiniti last night. Wish I had known that buyer beware. I knew i would have to replace the brakes. However driving home the car over heated after 5 miles of driving it. I noticed the radiator was hot on one side and cold on the other. This prompted me to remove the radiator cap. There was pressure relief but no spewing coolant. As luck would have it my brother had a bottle of coolant in his car we put it in and proceeded to drive home. The car did fine, and this morning I saw that the coolant needed to be toped off again (also checked the oil to ensure no coolant was mixing in the oil) so far so good. Now as a precaution I want to replace the water pump and thermostat, however I can not fine the thermostat, usually it is off the top hose but the top hose goes into a triangular shaped peice attached to the engine block. Could someone tell me where the thermostat housing is? Also after reading some of the threads here. i see people stating that if you turn on the A?C it will cause both radiator fane to come on. I did this and the fans do not turn on. Can someone give me some guidance on this also?
