I'm a new member from Florida. I've had my '91 240sx hatch for close to two years. The first year was spent trying to get the motor that was in it to run/fixing electrical issues and the leftover #aintcare of the owner prior to the guy I bought it from. Eventually, it got to a point where I had it running, but it was running super rich and would overheat, so I voted to pull it and build it for a KA-T setup about this time last year. I've learned a lot about this motor, and this is honestly the first motor I've ever built/gone through entirely. Not going for a whole lot of power as I plan to use it partially for street partially for track, and want to get used to how the car drives/handles before I stuff a ton of power in it, (it is my first 240). I've always been a huge fan of the schassis, mainly the s13, so this has been pretty killer. Here's a breakdown of what I've done to it since I got it (it was in rough shape):
- Had motor bored to 90mm, acid bathed, 3-way grind on the valves, machined crank.
-90mm Weisco pistons 9:0:1
-Eagle Rods
-ARP head studs
-ARP rod studs
-Cometic headgasket (90mm bore)
-ISR Fuel Pressure Regulator
-Walboro 255 Fuel Pump
-Z32 Fuel Filter
-Replaced all fuel lines
-New OEM fuel injectors
-New OEM radiator (Aluminum rad set aside for now)
-Electric Radiator Fans [wired to a switch]
-Bypassed heater core (It was plugged, and didn't feel like getting a new one at the moment.)
-Silicone hoses for radiator, and all new heater hoses
-New timing chain guides and tensioners
-New Cap and rotor
-NGK Spark Plugs
-Import Direct spark plug wires
-KA24DE Engine Harness from Wiring Specialties
-New stock MAF
-s14 o2 sensor
-New TPS
-New Coolant Temp Sensor
-New water pump
-New oil pump
-New thermostat
-Terrible eBay front and rear strut tower bars
-eBay 4-2-1 headers (figured it's getting swapped out for a turbo exhaust manifold later, so why spend a bunch).
-Nismo 60mm extended wheel studs
-Had to get a different OEM KA24DE ECU because the one I had was shot. This fixed a lot of issues.
-Competition Clutch - White Bunny clutch kit
-New outer tie rods
Car came with:
-Megan Racing motor mounts.
-Some sort of 3" catback exhaust (can't find any sort of engraving on it)
-Slotted & drilled rotors
-A ton of spare parts and some spare wheels
(I don't have any good pictures of it at the moment, sorry about that)
It's a slow project and I'm working on restoring it (I don't intend to keep the missile look forever). I haven't had a fun car in some time, and it's nice to have both a second vehicle as well as something I can pretty much do whatever with. My aim was to build this thing to be pretty much bulletproof/ready for boost. I'm in the process of breaking in the motor, and am leaving the turbo setup out of the picture until it's broken in.
Anyways, the motor is back together and running like a dream (for the most part). It's been a matter of working out bugs as I run in to them. So far I haven't had any issues, until the past few days. I've been driving it to work occasionally [to break it in], being that work is a good 25 miles away. Drives great, doesn't have any issues with cooling, idle, acceleration. It's not running rich or anything either. It has a strange issue where after 3-5 minutes of driving, the engine will hesitate/bog for a couple seconds [sometimes less/just a slight flicker], and the RPM gauge appears to lower, then bounce. Then it continues on the rest of the drive like nothing happened. I've checked all electrical, because that was one of the first things that crossed my mind/I've had issues with that in the past that were similar, and everything appears to be fine. All sensors are connected. Does anyone know what might cause something like this? It's not a constant issue, but for the past two trips to work and home, it has happened a few minutes in to the drive without fail, and never again during that trip. I'm a tad stumped, but I'm still checking things over/looking for possible causes. Not a lot of free time due to work, so progress with this thing has been slow to begin with. Just wanted to get some opinions to see if anyone has experienced this before.
