DCaff300ZX »
https://forums.nicoclub.com/dcaff300zx-u136230.html
Mon May 08, 2017 8:51 pm
Welcome Bellingham!
Congrats on the purchase, but with that many miles be sure to do ALL of your maintenance before trying for more power. Maintenance would be in the Z32's case most of the electrical connectors needing service, the injectors and connectors if not harness, and surely more as these old Ladies are very consistent with their elderly needs. Brakes will be the #1.5 item as the smaller '90 calipers and rotors need to go, then probably at minimum the FUCAs and probably the tension rods as well, if not the whole shooting match when inspected and trying to get an alignment. Most of us beat to the punch and go with coilovers and the adjustable parts to replace the aged OEM.
Also, be aware that the NA does not give much power nor cheaply, the reason for the "go TT" comment you will always get. It's true. Have both, no comparison possible.
Anyway, have fun and Good Luck!
