Maybe I should've put this in the tech section
... anyways I have a update!
Nolimit32, the pump motor had no circuit so it wouldn't have ran. After I threw it out i should have tapped it with a hammer a couple time and tested it... probably had contamination on the commutator and brushes...
I installed a OEM pump and replaced the filter, it still had the old gas (maybe 2-3 gallons) so I added a couple fresher gas to help. I know I should've drained it, but it has a flat rear tire, had no drain pan and i was lazy. lol So I turned the ignition on a few seconds to prime then cranked it for 5 or so seconds and it started up. I was very happy!!
Ran like s*** though... Couple of things I thought about what it could be, was a misfire, bad plug or coil pack, vacuum leak, bad gas (
) , maybe timing. So, I let it run till it got up to temperature. During this time, it idled around 1200-1400, that's when I thought it might be a vacuum leak. It ran really rough. It did come down to around 600-800, then it loped from like 800 to near stall and back. It never did stall. I did notice a liquid coming from the exhaust, it didn't smell like gas but looked like it. Maybe the old fuel blowing by. So after that I closed it up and went home. My next step is to drain the tank, put in new fuel and try it again. Also, I'm going to check for spark on all plugs and want to make sure all the injectors are working.
NoLimitZ32, what is the CPS? I'm guessing I need to have the ignition on to test? Is there a certain position it needs to be put back in at?
Looking forward to get the beast running
