shamoke »
https://forums.nicoclub.com/shamoke-u252322.html
Mon May 25, 2015 8:14 pm
i have a 93 nissan pathfinder 4x4 manual transmission when the engine is running with the clutch pressed it wont go into any gear its like something is blocking it from going in any gear.if its not running it goes into every gear fine as long as its not running. if i put it in gear and start the engine it will take off in that gear and i can shift it on the move with a little pressure .ive even tried to force it in gear while engine is running no luck.i have checked the clutch at the transmission it seems to move and operate properly.is there some kind of safety switch or something not working right to make this happen or any info would help this is my only transportation to work
