stevek85 »
https://forums.nicoclub.com/stevek85-u258698.html
Thu Nov 19, 2015 7:43 am
I have seen a couple of instances where the blue plastic collar around the P/S rack impute shaft makes a squeak noise. You would swear it was coming from inside the cabin but the sound was traveling up the steering shaft. To confirm this is the source of the noise, just spray some penetrating oil on the collar, the noise will go away if thats causing the problem. To fix the noise, remove the 12mm bolt for the steering shaft. Slide the shaft up, but not off. Pull the collar up and put some silicone grease between the rack and the blue collar. Slide the steering shaft back down, re torque the bolt and you should be set.
