I'm not realy sure myself, I'm sure others have tried it, I recall reading some one here played his SACD's but I didnt get a sense if this meant he got the "true" 5.1 experance or that it simply played.jshattner wrote:I don't believe the DVD player is capable of true SACD playback, so you're probably hearing the CD-compatible track on both players and not full multichannel sound.
Not the menu's as you would see while playing the disk on a TV in a standard DVD player. But the "DISC" button brings up standard control functions. Once up, you can use the ENTER switch on the steering wheel to move up/down and then push the ENTER switch to "Push" the button on the screen.tkeskic wrote: did you happen to know if this works with the menu's on the DVD?tk
Congratulations. I got my M45 almost two weeks ago. See zerothread?id=149399.spunkyvision wrote:Excellent Guys...Thanks for the replies.. I pick my M45 up in 40 minutes...WOOHOO!!!
An SACD should be able to be played but it will only plan the 2-channel CD portion of the disk and not the 5.1 portion. By using the CenterPoint feature, you'll still hear sound through the seat speakers. But that sound is processed through CenterPoint (much like Dolby Prologic II) taking a stereo feed and creating a spacial surround sound.larry.contrisciano wrote:Hi folks, my SACD dvd's seem to work fine in my M35 DVD drive. It sounds like surround sound to me, in that it is very rich and alive, and the front seat mounted speakers really come alive.
When you click the DISC button, you'll see the play/skip/etc. options on the screen. You can then use the Up/Down ENTER toggle on the steering wheel or the dial to move up and down the buttons. But, when on a button, you must push the middle dial button or the push the Up/Down toggle on the steering wheel to "push" the button. Let me know if that doesn't work.larry.contrisciano wrote:Lastly, someone in this tread mentioned that you can work the audio part of a DVD video concert, via the DISC controls.. I can't get mine to work, every time I try to use on of the play/skip/etc. options, it just sits there, so I guess I am doing something wrong. (Any advise)
Good for you man! Just don't sleep in the car tonight. I sat in my new M45 the night I got it (2 weeks ago) and my wife came out in the garrage to make sure I wasn't staying in it all night.spunkyvision wrote:Just got Home...LOVE MY NEW M45!!!! SWEET RIDE..sorry..I am little excited.
Thanks!! I am really loving it.superjv1080 wrote:Good for you man! Just don't sleep in the car tonight. I sat in my new M45 the night I got it (2 weeks ago) and my wife came out in the garrage to make sure I wasn't staying in it all night.
And welcome to the forums! Hope to see you back often.
Can someone point me in the right direction on how to do this?tkeskic wrote: however as noted above you can use your computer to stripe out the discs menu system, and then you will not have to deal with the menu system, just insert it and it starts playing
You shouldn't need to. I've played many DVD-Audio disks and one concert DVD so far and they all auto-play when I put them in the drive.spunkyvision wrote:Can someone point me in the right direction on how to do this?
