When I picked it up the owner went over the car with me, and made a point to show me the coolant level which I thought was a little odd, but we moved on. On the drive home I noticed the A/C would seem to blow warm, then kick back on to cold periodically. The transmission seemed to hunt around for gears sometimes and a little lag when the pedal was crushed, but I know that's par for the Infiniti course with some transmissions. But, made it home with no issues, and the car seemed to run very well.....noticeably faster than my old Q, which is great.
Anyway, tonight I drove about 5 miles to the notary, and then stopped in a drive thru. While waiting, I noticed the temp gauge heading north, and almost to the top. I pulled into a parking spot and turned it off, but didn't see any steam or noises (thankfully). After about 10 minutes I started home and the temp gauge went back to mid level (normal), but started heading north again when I was almost home. Parked it in the garage and let it sit for about an hour (again, no steam or gurgling). I took off the engine covers and saw no leaking coolent anywhere, or oil, or any leaks,,,engine looked totally dry. I started it up and put the HVAC to hot, and instantly blew hot air into the cabin. The temp gauge stayed right in the middle of normal for the 10 minutes it was idling, but when I looked again into the engine, I could see that the engine fan was not turning at all. I could hear the clicking like it should turn on (I assume the fan turns on by thermostat instead of constantly running..?), but nothing. When I was inside and could hear the clicking, I also noticed that the A/C would go warm and the RPM's would jump, then settle back down.
Any ideas where I should begin the troubleshooting tomorrow morning? As some know here, I have been a longtime Q45 owner, but the M is all new to me, and definitely want to start out on the right foot with repairs and maintenance. Your responses and help would be greatly appreciated, especially since my wife was not thrilled with this purchase, so hopefully this repair can be made quickly and quietly!!
