New M35 owner with a question regarding shifter console light
jt@justdrift
Car: 2006 m35
previous cars: 2010 G37S sedan 6MT
2004 G35 sedan
2004 G35 coupe
Hi all!
I just picked up a 2006 M35, and shifter console light is out, so I tried replacing the bulb with a new #74 bulb. The weird thing is,
the bulb was indeed blown, but there seems to be nothing for the little black connector with yellow wires to connect to.
Am I missing something? Nothing under the center console area seems to be a connector that belongs to the plug.
Thanks!
JT
Ilya
It's possible the light is soldered in place and is a tiny LED? Did you take the shifter assembly apart?
jt@justdrift
Car: 2006 m35
2004 G35 sedan
2004 G35 coupe
It's a 74 bulb. I did have the console removed while trying (in vain) to install my grom kit. The weird part is, that the connector that's attached to the shifter console has nothing connected to it.
Ilya
Ahh okay, sorry misread/misunderstood.
Have you referenced the FSM? It might have a diagram for the shifter which would help you narrow down where that harness goes. Check the FAQ thread in my signature for that info.
jt@justdrift
Car: 2006 m35
2004 G35 sedan
2004 G35 coupe
Thank you much! I'll check that out:)
