Please ignore the bugs. Had to drive friday night and think someone was shooting a bug machine gun at my car.
I painted it blue to go with the led back light i was putting behind it. Can be seen here
However not sure I like it to much. so will most likely make another and paint it black. I also got the switch ready to be wired to turn on and off the under glow and back light.
goes in the empty spot to the far right
had the led installed to let me know if it was on since there is no dummy bell for this switch. but led actually caught fire and melted the inside of the bulb. make sure to put a resistor on the bulb if you do this. For now I wound up taking the bulb out and covering the hole with some electrical tape.
Today I wired up the and mounted all of the lights. all works great except for the driver side neon. I will have to check to see if its the wiring or the bulb that is the actual problem. This will most likely come next weekend as I work all week.
